Can anyone recommend a power distribution unit ?
Fz-1 hooks to battery, if im not following you sorry, long day getting bike to dyno
I haven’t used a fuse block. The instructions for the FZ show 3 power inputs, 2 from the battery (pos and neg) for continuous power and 1 from a switched +12v circuit.
I’m looking for something that connects to the battery and is smart enough to detect if the motorcycle is on or off and provide switched power to a GPS unit for example. I know quad lock has a smart charger that detects the battery output voltage and shuts off if it’s goes below a certain threshold. Do these units work the same way?
I don’t know if I’m comfortable enough tapping into the power cables myself to be honest. Am I out to lunch or does the above exist somehow ?
I think this is what you’re talking about. It doesn’t require splicing into a switched power source.
Thats is right i connected to rear running lights right beside battery box i tapped in there
Incase anyone in the future is looking for a product that fits the description. This is it. Super cheap for how well its built and smart enough to not require any splicing. You can splice into switched power if you want but in Automatic mode its more than good enough. Thank you @dougl
Fuzeblock is more versatile with better control/transparency for a power user building out an accessory stack. Thunderbox is a simple quick way to get something connected. Take your pick.
The Rocket has a 20 amp fuse for accessories. Where would you tap into that?
