Front Accessory Socket No Power...Has Power!
Protonhound
Turbocharged
Calaveras County, California
2023 Rocket 3R
So as some of you pointed out the manual is lying about the front accessory socket being permanently live and not having anything to actually plug into it I was using my VOM to test for continuity which is pointless on a switched circuit which this definitely is. The fact that I was not getting any voltage reading with the bike both on and running can only be due to it needing to sense some current draw before switching on. Once I plugged my brand new charging plug in it worked just fine even though I had to tighten up the pin contacts for a stable connection.
I've connected both my Zumo XT and Denali DRL's to the DIN plug and all works great, on and off with the bike. I did brake the terminal on the DIN plug and replaced it with another from Amazon, very fragile, breaks as soon as its bent.
