R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,580
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
What do you mean by above ecu cant adjust injector size?
As in with the only map editors available to us that I know of for these ECUs being TuneECU and TuneBoy (Triumph factory one notwithstanding), one can't access the injector flow rate variable to edit it.
Or fuel pressure for that matter.
You can change AFR target and quantity of air in mg x20, and the ECU calculates what injector on time is needed to supply the right amount of fuel to make that target AFR based on the inputted quantity of air, and adjusts pulse width of the injector to deliver that amount of fuel.
But that's when the ECU thinks the fuel pressure is 3 bar and injector size is 330cc or whatever the stock ones are.
So if I use 840cc injectors instead of 330cc and don't touch the map or fuel pressure, the fuel delivered will be like 2.5x what it was with the smaller injector. = massively rich condition so bad the bike won't run.
I have to drastically reduce the mg of air in the L and F tables in order to compensate.
Add to that running higher fuel pressure for (a) overcoming intake air pressure and (2) delivering moar fuels capability for moar powers.
And the fuel tables become quite warped because one is compensating for inability to program ECU with different injector size / flow rate or pressure.
Oh yes and then add in a 2.5 bar MAP sensor when the ECU thinks it's a 1 bar, (another variable one can't change in these ECUs) and tuning the map tables gets very tricky.
This is why when people get serious about tuning they will gravitate toward aftermarket ECUs.
