R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,381
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
Oops been a while since updating everyone here, the MCI were unable to secure insurance since so basically no motorcycle race events in the Republic this year, and possibly ever again :-(
In parallel, I suffered an electrical gremlin in the 5V circuit that was messing with my engine management, given all the sensors that are on the engine subharness on the 5V circuit.
This happened a few days before the dyno date, so I postponed it.
It was probably there a while giving me jip, but it got so bad at this point the bike wasn't running right at all.
Funny you could think you have a faulty primary TPS, but it turns out to be corrosion on the inside of the crimps in the engine subharness. On the outside they are clean and shiny, but inside they corroded somehow. Anyway it caused the voltage to dance around a lot, and when your mapping is very different at only say 0.72v to 0.95v, it makes things very erratic.
Anyway got that sorted and moved on with my life.
The stock MAP sensor is a "1 bar", but really more like 1.2 bar, in any case it don't work with boost.
Made an adapter, fitted the 2.5 Bar BMW MAP sensor to Triumph harness, setup PCV for pressure based tuning, and off I went.
Ever seen a Rocket idle at 340hPa?
Finally got some time (and weather..) the past few days to get out for some test & tune for low throttle positions i.e. 0 - 7%ish range where the L tables govern fuelling.
Good to get back out on the beast and have the new MAP working.
Some fine tuning now so it's smooth and gentle around the streets, and then we switch over to TPS based tuning and pulling timing too.
