BreakAway Cruise Control
ok. shipping is to marysville, washington. 98270 paypal?
sure give me an address name etc etc I figure $15 .00 for shipping to USA my paypal account albertaduke@gmail.com name is Patrick field-robinson just in case.
I will pack the whole unit with the instruction manual and send it as soon as I receive confirmation from paypal..
I wont bore you with how to install - lord knows there are enough instructions included in the kit.
OK - it took a couple of hours to fit, including beer breaks and swearing. Not too bad to fit, except the 'ring' part would not go over the hand grip.
IMG_20140321_160023_277.jpg The external size of the grip is 5cm - IMG_20140321_155949_046.jpg the internal size of the ring is 48mm - so it wouldn't fit.
The problem is, if the ring does not fit snug up to the switch then the bar thingy will not reach.
So the only way I could get this fitted was to trim the end of the rubber grip.
I did clean it up a bit, but the ring covers it so no big deal. It's just if I ever take this off then I will have to buy new grips.
Once that was trimmed it all went together pretty easy.
Well, until I went to adjust the brake part. The rubber bumper is adjustable but has a lock nut. So I backed it off so I could adjust and at that point I heard the sound of it dropping onto the radiator cover, never to be seen again. So for now I have left it off until I can get another nut for it.
But now I have been able to adjust the lock to where I want it to be, it does the job. I will be getting a new nut for the brake thingy tonight as that is a must. You just don't get time to de-select the lock in a butt clenching moment.
I'm happy with the look, it doesn't intrude on the grip width too much and it operates the way it needs too.
Overall I am happy with it. Used it on the freeway and it was nice to be able to rest my right grip to flip off HD riders :) (FYI - I still own 2 HD's)
Worth the money? I would say yes. The R3 needed a throttle thumbscrew at least, but they must have been asleep that day during the design.
Interesting, i never had to trim my grips, the only thing I found that I didnt like was that the when you repace the nut on the front brake, the bolt is not long enough after you attache the quick release angled bracket. the nut threads on but not enough to seat flush with the bolt....hope that made sence
This must be a different model as I didnt have to connect to the brake lever bolt.
Now you have me curious, could you post a pic of the back side of the Breakaway please and thanks? im interested in how the quick release (brake) is set up, i noticed a billeted collar attached to your handlebar in front of the switch housing, it that a part of the breakaway as well?
Thanks again
Thanks again
I will try and remember to take a pic of it tonight. But the collar on the left side of the switch housing is part of it and its what holds the 'bar' in place which in turn holds the ring in place, (stops it rotating) - the front brake release is just a straight push from the bumper (which I lost the nut for) and that releases the lock when pushed back.
Write your reply...
