Al Burdon
When fitting the leading link for my sidecar I had to extend and re route the front brake lines. I have a ABS Roadster so the 2 lines from the master cylinder was not an option.Here’s mine although only bought these as they were cheaper than running a splitter in a 3 line system and slightly longer to accommodate the new bars without straining.![]()
As indicated in the attached picture only the lines from the connector under the right hand neck cover to the brakes needed replacement. So for those with length issues for custom bars ect. it will only need the line from the same joiner to master cylinder. (Note check the union required at the joiner)
