J, can you tell me how to remove/replace the turn signal indicator bulb from my RPM gauge?
Thanks
I plan on looking into it soon. According to Kisan, if the indicator light on the speedometer flashes it is incandescent and replacing it with LED should remedy the problem.
@barbagris says it's already LED and can't be replaced, so I don't know- apparently he does.
Plan B would be to install a connector on the two wires headed to the instrument panel and leave it unplugged. I don't need the indicator light, as I can see the front signals themselves just as easily to confirm that they are working.
Calling on
@DEcosse to elaborate on the LED question and the idea of unplugging the light.
Here's an old post he put up showing the wiring for a Roadster/Classic, I believe. What is late model? If so, could you still unplug the GW and GR wires leading to the instrument panel?
From
@DEcosse .....
One of the members asked me about swapping out the instruments
On the RIII & classic, you can swap to pretty much anything you like (after-market or even some OEM)
However the Touring &
Late Model use CANBUS so not much you can do there.
I created a Key that identifies each of the signal wires at the instruments.
A couple of quick notes:
The indicator lamp signals for Neutral, Oil Pressure, Low Fuel and MIL are all active 'low'
The indicator lamp signals for Turns and Hi Beam are active 'high'
The speedo power 'out' is a switched 12V for the speed sensor.
The Alarm LED are LED voltage level signals i.e. connect directly to a bare LED, not 12V-ready LED.
Hope this is useful for anyone who chooses to go that route - thought that I should just post it up for general reference.
Ask me about my
Hands-free Key-Less Ignition System Or Headlight Relay Kits
*Note there are two Green/Red wires with completely different functions - just 'Brilliant' Triumph.
(that has been the same regarding those colour designations for ignition power and left turn on just about every Triumph in the Hinckley era)
