Need some opinions on where to start trouble shooting.
I turn on the ignition and get a full sweep and all things look normal for start however I just get a loud click when I hit the starter button. I have tested the battery and it has a full charge (PC 625)
Full disclaimer. A few weeks back I wired up a set of the "WalMart special" driving lights (aux light circuit), GPS (direct to battery with fuse in between), replacement accessory connection (replaced standard euro style) and stebel air horn (existing horn circuit with relay added). Wired up everything and tested it all out. Everything worked just fine and the bike started no problem. Imagine my surprise, thanks to everyone for their posts for each of these installs. Also, it should be pointed out that I have had previous ignition switch problems however they were resolved quite a while back thanks to the help of Skip. I was monkeying about around the ignition switch due to placing the horn directly in front of it.
So where to dig in from there? All suggestions welcome.
Cheers
Cheers
