Backing down the driveway ?
Croft, thank you for that link to Discount Ramps. I ordered the one you recommended, and it arrived today. Just as with some toys delivered by Santa, "some assembly required". There is a sticker on it that says "Limit 1,250 lbs", and the heft of the unit suggests that it will be up to the task.
I reckon I can make a turntable with half a sheet of form ply, a rubber mat , 6 heavy duty casters and a small wooden ramp to ride on and off the base ,you could attach some timber to the underside edge to stop the base from tipping with just enough clearance for the casters to spin, Bunnings Hardware sell inexpensive 100Kg casters, I never thought of a turntable ,but as my shed is full of toys it would be handyfor other things as well ,that's it I will make one and post some pics.
Going to have to be a good sized turntable to move that Customline around mate.........
Hope that bike dolly works out then. :) The benefit of one of those vs a turntable is that you can just push the bike around the garage any way you want. Perfect for just spinning it around or shoving it into a corner to take up minimum space without spending half an hour maneuvering the bike back and forth on the wheels.
I'm glad this thread popped up, my wife wants to sell her sportster and get a fatboy low (the bike,not me), I'll get one of the turntables for her new ride, make her life easier if she takes it out when I'm not around. We have a brand new house, but the builder hasn't paved the driveway yet, and it will still be awhile before they do final lift on the street, it's quite the bump rolling out of the driveway, safer for her to drive it out.
You may want to point her towards a Thunderbird Commander, easier on the wallet and lots more fun. Sits low too...
Bike is home, and the dolly works. Again, thanks to Croft for the recommendation.
The ramp has an oblong-in-cross-section wedge at each end, with an attached lever. As in the photo, the lever is away from the ramp, the wedge lifts the ramp ever so slightly so that the dolly wheels leave the floor (as can be seen under the rear wheel of the ramp in the photo), and the ramp is sitting on the garage floor.
Even so, the bike is heavy enough, that on the first try, the bike just pushed the ramp forward. Only when I had my daughter stand on the opposite end of the ramp, was there enough friction to keep it from moving, and allow me to ride the bike on it. Also, having my daughter up front, she could provide minute direction to keep the front tire centered.
The height difference is minimal, and I had no problem maintaining control of the bike on the ramp.
The side piece of the ramp accommodates the kick stand. The ramp allows for five different positions of the side piece. The Rocket's wheel base is approximately 68 inches, and the kick stand is approximately 30 inches from the front, placing it forward of the middle. Even so, the next forward position for the side piece was too far, so the Rocket sits slightly back of center to make sure the kick stand rests on the side piece.
Once on the ramp, a stop bar was placed in slots behind the rear wheel (there is one stop bar at either end), the wedges were turned up, putting the wheels on the floor, and my daughter and I turned the bike 180o, just as advertised. I caution, that there is enough friction in the system, that we exercised care to not tip the bike. The key is to keep pushing and pulling low. Pushing the appropriate place with one's boot works well.
And, one of the goals of having the ramp, independent of wanting to head out, is the facility with which one may "shove" the bike against the wall leaving more useable space.
And to Tomcat's point, as much as I wish it were true, my daughter (first year with a moto license) rides the 250, and the CTX700D with its automatic transmission is a necessity in the rush-hour traffic I face in daily commuting. The timing for the Triumph is that we are approaching empty-nester status, and that will enable my wife and I to do more two-up touring.
Looks great, glad it all worked out, I have never used one of those in person just lusted (or something) after one but so far had issues finding one large enough and in a location closer to home (with cheaper freight...) than the US. Now you just have to figure out a way to make it stay put without someone holding it in place when you load! I'm sure with practice you'll be loading it solo with no trouble at all in short order. Maybe place some thin rubber mat of some kind under it to increase friction...?
Btw, one thought - you may want to consider getting a strap of some kind to wrap around the front brake lever after you've loaded the bike (to create a parking brake). Would be a good extra security measure to keep the bike from rolling off the kickstand while you're muscling it around.
Maybe just leave it in gear .nice pictures .very good idea .
Just a thought. Get a couple of meters of webbing strap to attach to the underside of the dolly, lay it out on the ground and ride up over it. Weight of the bike will stop the dolly moving away from you when you ride up.
