A little perplexed and curious.
You straightened it out though
i had a similar situation about a week ago...came into a hard left uphill corner too hot...had to brake while leaning!!HATE THAT...new rear Exedra max too!..slid the arse out to the right while scraping the peg...a bit of opposite lock and she gripped and straightened up again...made my arse pucker a tad...took a couple of quick deep breaths and all was g!
:inlove:inlove:p:eek::eek:
Do you think we might be victim of a bad batch of emax tyres :eek::eek::p
...no. it was all my fault...too quick...braking at the wrong time into the corner a bit too hard and bingo....sliding..just for long enuff too make me stop breathing, then it was all good again.
Had the tyre been a problem i would have been sitting on the road. The tyre did all i was expecting it should.
I just love these bikes! You can flick them around when you need to and they respond well.
The busa was 50 to 100m ahead and as I cut through the apex my peg feelers were dragging at about 100kmh and I shifted to fourth and opened the throttle to close the gap.
You were at the Apex and correct me if I am wrong you downshifted to fourth and opened the throttle?
most possible cause of losing traction was your engine speed when you downshifted and opened the big boy up, higher revs faster turning rear wheel, in a lean angle:eek::eek::eek::eek::eek: makes the old arse pucker does it not:D
engine speed did not match road speed, as the great Jackie Stewart said never get back on the throttle coming out of a turn until you know you will not let it off
Last but not least slowdown and enter the turn with a speed that will let you increase throughout the turn---a smooth steady rider will outperform a fast erratic rider any day(not saying you are a bad rider)
Nailed it Scotsman! :thumbsup:
