2013 R3T ECU Reprogramable ?
Idaho Red Rocket 3
Nampa, Idaho USA
2006 RIII Standard Bagger w/Fairing
I believe the 2013 R3T ECU is reprogrammable with TuneECU. Is this correct for a bike purchased October of 2012 ?
Next questions.
1) What is the expected average stock Horsepower and Torque for an R3T on a dyno ?
2) Is the air intake system and exhaust restrictions the same/equivalent on an R3T as the Standard and Classic ?
3) If a Standard or Classic stock tune were loaded into an R3T should the power output be expected to be the same/similar as a Standard or Classic stock power output ?
I know about all the ways to increase power to max output, but I am looking at making it equivalent to stock first.
Bill.
Dynojet 98-100 hp 158-159 ft-lb
R3T intake is the same. Exhaust is more restrictive (diverter box under bike).
No. R3T ECU will not accept same map. Exhaust is the issue. With the same full exhaust system and mapping it will make the same output as any R3.
Start with the map I have uploaded on this forum. Then work from there.
-Wayne
