Mongler07
Nitrous
Megg tests only for insulated resistance load wires. All it does is tell you if the insulation has pinholes or damage. I do it on a weekly basis installing heated floors. The tool is a megohmmeter. it usually pumps in like 10,000 volts into a wire. Think of a garden hose put to a high pressure to check for small leaks. The reason we do this is for say a, ignition system coil that a stray arc can be undetectable until full load and heat comes into play. All it does is tell you if there is damage to the insulation holding back said power source. If a heated cable has this damage it will wear out FAST due to thermal expansion and contraction during heat cycles and failing prematurely. The tool is close to $200 for a klein, $400 for a fluke and uses 8 AA batteries and will give you a hell of a shock if you tough it in its test mode.I think you'd have to be and electrical engineer or an industrial electrician/tech to pickup on that term. I've never run those kinds of tests but saw them done at a generation plant that I worked at. A Megger tester, also known as an insulation tester or megohmmeter, is a portable device that measures the resistance of electrical insulation to identify potential problems. Not a test I'd run - pretty high level thinking though for a DIYer.
