dobro
No problems since the ignition switch was replaced. There weren't any visible indications of a problem on the exterior of the switch. When I get in the mood I'll crack it open to see if the apparent malfunction is visible inside the switch.
Well sh*t, here it goes again. No problems for 6 months after having a new ignition installed then today turned the key and nothing--no ignition, no fuel pump, no dial lights, no headlights, no turn signals, absolutely no sign of life except the horn worked. Charged the battery and still nothing but the horn. Went inside to look at your suggestions from my last episode of this trouble 6 months ago then went back outside just for the heck of it and raised the kickstand and turned the key and BINGO everything lit up! Keeping in mind that I had all the ignition wiring check and the ignition replaced 6 months ago, what do you think are the most likely culprits since only the horn was working before everything suddenly resumed working? Thanks.
