2.5L Rocket Stroker Engine Kit with 6 Speed Transmission (R&D)
Just out of curiosity, was (or can) the front of the crank drilled and tapped to accept a fastener for a supercharger drive pulley.....
Saves that problematic step for the few considering going all out with a stroker/supercharger combo.
WOW ! What will it cost when you get the kits together ?
Until it's in the engine running, road tested, we won't know the final score, but you're looking at TTS or Carpenter Racing package level price
Excellent question. I had originally specified an integral stud - would be better than a perfectly drilled stock crank with a balance welded stud.
However it became apparent that with the weight of the crank was too much to be spinning it on a 12mm x say 80mm long stud, when machining down the crank, it would flex etc. So we went with the M12x1.25 bore like you would have with a TTS kit.
Only 20mm deeper to take a longer bolt or stud. And drilled perfectly on & parallel to crank axis.
Thought was also given to beefing up the bolt/stud from TTS M12 to M14, but that left no wall between it and the timing gear key slot.
While we're at it, the 2 pressed-on crank gears were going to be integral too, but this drove cost up so much I said nuts to that let's just weld the stock ones on.
That goldy flaky stuff is just cardboard fibers from packaging.
Yeah I need my motor to fail so I can justify all this to wife for new 2018 Rocket....lol
Tell here that because you had to carry her extra weight as a pillion, Triumph wouldn't warrant the engine failure. Hence the need for the stroker kit......
Think she will bite :)
Write your reply...
