2.5L Rocket Stroker Engine Kit with 6 Speed Transmission (R&D)
BTW: What will the new stroke be in mm ? Does the bore get changed too ?
Here is what the first post stated for a 2472cc engine.
"The Rocket cylinders are 765cc each, with a diameter of 101.6mm and stroke of 94.3mm (an oversquare motor). If we increase stroke length (that's what she said) to 101.6mm to be perfectly square, the engine CC will rise to 2,472cc (or 2.5L :D)."
Guessing the stroke is 101.6 mm from 94.3.
So start growing pure Diamond engine cases. Should only take a few million years.
Must be some poor quality diamonds and my Irish friend will not go for that:D i do not remember much from HS (except my Latin teacher was hot) but a diamond takes around a 1000,000,000 years to form/grow/produce:eek:
Well, the crank was only Euros 256, while the setup was Euros 312,000. How he amortizes the setup over six cranks sold, now that is the interesting question.
Write your reply...
