10" rear wheel
chandelierman said:
It is not a problem making a wheel wider and bigger dia,check out the DEGET website :wink: it has been being done for years
Shockingly, the vmax OEM rear wheel is only 3.5" wide, so the maxers make it wider and taller so that it will take a modern radial tire.
The more adventerous guys also notch out the swingarm where the tire meets and then reinforce it elsewhere so that they can get a respectably wide tire on the back.
I was looking into it so that I could put a car tire in the rear of the max, but it's not cheap. I was looking at about $1,500.00 to get a modified wheel, which kind of detracted from the cool factor a bit.
chandelierman said:
Also notching out the swingarm is no big issue either,the Vmax guys have been doing it for years.
Looks like i have come along right in the nick of time
Notching R3 swingarm is very easy job, will not need strenthening
BST could make a nice wheel up, I've heard they do specials. :wink:
We've always known you were "special" Les. :wink: :lol: :lol:
When is your latest incarnation going to be ready mate?
245
Hi,
I have a 245/50-16 federal S595. The drive shaft case/cover is already scalloped... the stock tire would rub if it wasn't. I had to remove the Rivco chrome drive shaft cover, the front retainer spring was rubbing the tire. There is maybe 1/4 inch clearance. MAYBE. So, I can get a tire that measures 9.8 inches section width.
link to the pic.
