Winter modifications
I'm not against changing to a toe shifter, just would like to maintain the leverage applied by the OEM shifter verses no leverage ergonomics of one attatched straight on the spline. Might find another OEM one and remove the heal section to try.
Warpo,
How do you figure that shifting through all that linkage requires less force than shifting directly from the splined tranny shaft?
Postage for you US$7.61. Ours is US$47.63 EXTRA or US$55.28
Postage for us in Oz
Postage:
US $39.71 (approx. AU $58.03) International Priority Shipping to Australia
Item location:
Haltom City, Texas, United States
GST and Import charges:
US $15.53 (amount confirmed at checkout)
Physics, and a Pixie's prod versus a Bear's paw!
I would reckon the more fulcrums and moment arms added serve to increase the force neceseary, not to reduce it.
After all tis not a pully system.
Winter -- funny how the mind works (unless one is in So Cali, Brownsville, or Orlando). All this nice weather recently, and I was too busy to look at the bike. 23ºF this morning (my Honda CTX700D would NOT start this morning, and fortunately, the motor pool people are prepared for that, and a guy came by in his Gator and portable boost unit, and I was on my way, with heated grips and seat, plus plug-in vest and gloves), and expected 19ºF tomorrow morning, and I have the urge to do something to the bike. Of course, now it's a pain. Thanks to a suggestion from @Rocket Scientist a while back, I now have three 1,500W electric heaters to heat our 12' x 24' garage. But the joke is on the electric company because we have an electric car and jumped early on an "experimental" electric rate some years ago (first 750 [!] customers to sign up), and with that rate, we have a meter that measures by the hour, and they defined a "super off peak" rate where they give the electricity away (started six minutes ago as I type this -- 2300 EST) -- and our 2019 Chevy BOLT (a number of y'all saw it at Maggie Valley last) just started charging.
So what is all this fuss ?
In the process of installing a variation on @JSHRAM Coil Over Plug mod (COP) for standard coil removal with fancy parts from @DEcosse -- I somehow managed to create an odd short in the horn wiring (y'all may remember I aped @TXtriple Installing An 18" Air Horn...'Cause Bigger Is Better!, so tapped into the bike's horn circuit - which is nowhere near the sparkplugs, but now when I turn on the ignition, the horn blows to let the neighborhood know I'm about to start the bike -- or work with TuneECU.
Hopefully by morning (I'm working night shift this week and next) I'll have this sorted.
I hope your not backing it up!
Fulcrums and levers
Lever - Wikipedia
Doesn't the lengthened lever length increase leverage? If you had an equivalent length lever direct to output shaft you would need a very long foot.
Warpo,
Is a wheel Barrow easier to pick up and rotate on the tire with or with out them wooden things you grab on to surely you could just grab the tub and lift. Oh and I also pointed out how many miles I have on the OEM heal toe shifter can play a big deal in it.
For me... very little force is required to effect the gear change. I personally like the direct feel of the toe shifter without the linkages. My toe has much more neuromotor control than my heel, specially when using the Bull tuned Daytona boots. The heel just has more force. A lot of people use the heel shifter with the toe to push-shift to the next gear. It feels and looks kool doing that. Originally I just wanted the heel shifter off because it gave me the option to use the whole platform to place my foot on. Plus, I could tuck my foot about one inch closer to the bike without the linkages. Plus, I think it looks kool.
Scott... If you like your heel shifter... go at it. A lot of people do. The shifter I sent you is a piece of motorcycle art. If you are not going to use it please bring it to RAA East or mail it to me. Perhaps someone else will see mine and say... hey that shifter looks kool, can I try it? and it gives me the chance to make a fellow rider happy.
