Hi all!
OK Here is a goodun.
I used to have the old cold start issue.
I have installed the secondary relay to the starter relay and it improved the spin of the starter motor, consequently the bike started alot easier right down to 0 degrees.
I have installed the headlight relays and improved the beam quality and again reduced the load on the ignition switch.
I had completely bypassed the ignition switch and installed the three relays setup with a toggle switch for the ignition. This did not make any difference at all so I changed it back.
I have had great success with the double relay feed on the starter circuit till a couple of days ago. Now when I turn on the ignition all is good but when I press the starter button the bike cranks a part turn, stops, then resets on the startup sequence, like a flat battery fault. The battery has a full 12.68v and I have even tried to jump it from a boost pack which has 12.38v and which has usually been successful.
I have been through checking all relay connections, fuses and modified/repaired wiring connections. Could this be a sensor issue somewhere?
