Which Bluetooth ODB2 Connector works with the Rocket?
What Pisces me off are ram mounts waterproof cases. With one style you have no side button access, so if the screen turns off you are screwed until you can open the case to get accesss.
With the other style you get side button acess but cannot charge while device is in the case so mostly useless for converting a phone into a GPS permanently.
Why is it so hard to build a slim case that is waterproof and allows for charging and buttons:/
My favorite phone holder are designed by Slipgrip. I've used 3 of them for different purposes and they are top notch, un bulky solutions. I've never been too concerned about water proofing, because of the things you mention above..
Check them out http://www.slipgripcarmounts.com/
OBDI is the computers before 1996 each manufacturer had there own connector so i have a couple of boxes with different connectors. there are exceptions around 1993 to 1998.
in 1996 the manufactures went to a standardize connector ( the obdII ) along with that they put in place the standardize generic OBDII codes P0001 to P1000 . they also manufacturer specific codes. abs,anti lock, 4x4,body, trans,ect modules
what info you get from the computer depends on the type of scanner you are using.
on are scanners if we limit the info to just a few items then the data is much faster if we have about 15 lines then it is slower.
when we go into a chev obd2 then we have about 15 items when i put in the vin# info we get 3 pages info. when i go into a foreign car obd2 i get about 5 items.
the rocket computer is not that complicated but i do get a lot of info when i put my scanner on it. i have not tried the tune ecu so i don't know what it has. hth
As long as I can get RPM, Speed and maybe 2-3 other readouts, im satisfied. I dont need to see vacuum pressures or intake pressure or anything while I'm riding! I am a graphic artist by trade so I am going to design my own dashboard interface with BIG displays.
http://lifeproof.com - but only for the Apple devices and some of the biggest selling Android ones. The good accessories are mostly made for Apple devices because they sell like hotcakes and there are only a few models any given year so easier to have time to design and build cases, I guess.
Write your reply...
