WHEEL BEARINGS - THE DOPE
Some more dope:
Thanks to simplifying ordering replacemenslts by 10lbull, the Nachis I listed earlier have arrived. All marked as manufactured in Japan, the 20x47x14 size has a few options at vxb.com, the Nachis with red seals seem to be the most highly regarded and are what I ordered.
Time will tell if they're any good, could be Japanese trash, don't know yet.
There is more to bearings than who made them. Some manufacturers are better than others but many other factors apply as well. ABEC- ratings tell much about a bearing. Size tolerance, axial and radial free play, ball sphericity to name a few. Just as important as the bearing is how they are mounted. Bore size in the wheel, axle OD, side load from bores too shallow or too deep, adjacent bore eccentricity, bore roundness, and on and on. Then there is the installation: beat them in place and you risk damage. Press on the wrong race and you risk damage, put too much pressure on the race from overly-tight axle nuts and the inner race distorts. Need I go on? Some wheel bearing issues may be specific to a particular wheel for the aforementioned reasons. Others may not be.
Buy name brand: NSK, SKF, Timken, RBC, INA and others and ask for better grade ABEC-3 or 5 specification bearings. These manufacturers have reputations to protect; generics do not as it is almost impossible to determine who made a particular bearing if it has no branding on the race side. Check wheel bores for imperfections, gouges, evidence of spun races, etc. Check spacer ends to see if the bearing(s) inner races have been spinning. If they have, chances are the spacer is shorter than original. Look for wear marks on the axle OD. Install them with the right tools, check feel after installation and then once the wheel is in place. If it doesn't feel smooth, something is wrong.
Replaced rear bearings due to noise ( loud at a roll ad seem to go away at speed ) installed new bearings and lasted about 1000 miles? Removed rear wheel for inspection and found I had nicked the wheel when removing old bearing. Not much, but enough so new bearing not seated all the way. Dumbass mistake on my part. While researching problem I ran across the correct way to install rear differential to swing arm and wheel. It needs to be done at the same time. I had lube the driveshaft splines and then installed the wheel. That is why the oem parts failed. Again, my screw up. I'm not sure who had posted it up or where I found it. Been awhile. Cleaned up the wheel. Ordered new bearings from Baxter's in Iowa. Reinstalled the correct way. No problems in the last 30k miles and five years. Just a little information that may help.
The Nachi's are all stamped with ABEC-3 on the inner race, so a sign they might be quality, but we all know how QC really determines what leaves the factories
At least they are not Chinese.
So then, my friend, what IS the meaning of is???
Gratitude for that informative post.
I learned some good $hit!
Well, Clinton thought is was.....
So exactly what is the proper description of the bearings best for our Rockets?
I currently run the AXS 5204, 6204 & 6305. Cost me $52.28 back in 3/29/16 from McGuire Bearing Company in Tacoma.
