Jim/Maine
- Joined
- Jan 12, 2011
- Messages
- 242
Interesting read guys, and way above my pay grade. I am curious that compression ration has not been mentioned?
I have always attributed the relatively low compression R3 to working well with lower octane fuels. And my seat of the
pants cannot seem to get more out of higher octane and I never have knocking. Ethanol is another
matter -- total bs in all ways. I use a stabilizer which, theoretically, modifies the Ethanol, with every fill up. I do not recommend
use of aviation fuel which is 100 octane, 100LL (low lead) which is anything but low lead. Obviously the lead is incompatible with
catalytic converters but I have heard that it can also not work well with modern engines, valves mostly, designed to run with no lead.
My choice of gas is usually to use a busy station with lots of volume to preclude stale gas, and I usually go mid range as that, I
think, is a mix of the lower and higher octane tanks. Seems to be the case especially where it is obvious there are three octane
options but only two tanks. But the above is with a -- so far -- stock engine.
