When I was specializing on wrenching on the high end German stuff, Benz and BMW we had an ethanol content analyzer. First thing that we would do for weird drivability issues was test the fuel load. It wasn't uncommon to find the content as high as 30-37% on the ones that were really acting up. 15-23% was pretty usual.
I see similar results locally. Drivers mix ethanol in a portion of the tanker, and may add it first or last. 30-32% ethanol is not uncommon, 15-20% is normal. If ethanol sits in a tank it separates relatively quickly.
Since there seems to be a LOT of confusion as to fuel differences around the western world, I have put this list together with the help of a lot of others.
RON= Research Octane Number (Chemical test) - European/UK/AUS/NZ pump octane number
MON= Motor Octane Number (heated research motor test)
PON= Pump Octane Number (AKI/anti-knock index - R+M/2) - US pump octane number
Europe/UK:
98 Octane____________
95 Octane_______________
Shell V-Power (typical analysis)
98.3 RON_____________95 RON__________________99.7 RON
86.9 MON____________85.5 MON________________87.9 MON
92.6 PON_____________90.25 PON_______________93.8 PON
AU/NZ:
Actual test data or info from suppliers is scarce to nonexistent, but this data comes from several suppliers.
Premium___________
Regular
95 RON____________91 RON
85 MON___________82 MON
90.5 PON__________86.5 PON
US:
Premium 93 ___________________________________________
Premium 91
(actual results from 25 stations)___________________________(Actual test results)
98.5 RON________________________________________________96.3 RON
87.9 MON________________________________________________87.9 MON
93.2 PON________________________________________________92.1 PON
Regular 87 (absolute minimum US standard)
91 RON
83 MON
87 PON
While this is not an absolute, and some locations may be higher or lower, I hope this helps clear up the BS.
