JohnnyCanuck
I went to my local Triumph dealership to get some washers for my 1st oil change. They only carry 1 size of washer (part # T3550605 - sump bolt washer). I was under the impression that there are a total of 3 bolts that must be removed for the oil change - 1 of which is a different size than the other 2. Should there not be 2 different size washers or will 1 washer size fit all 3 bolts? Wanted to find out before I start the actual change.
Also, has anyone tried the K & N - KN-204 oil filter? Thanks!
