ok.. so ive rebuilt the engine (that was running fine before..but I had the loose bolt on gear selector issue) so had to strip it and rebuild it... All seemed good..
I put in 5.2L of Castrol 4T 10/40 and ran the motor.. All sound good... I should point out that I am running it without an oil pressure switch at present as its seems impossible to get one here.. on order but who knows when.. but anyway.. the engine is running sound... valve shims done and everything...
so whats the problem now??...
All the oil disappeared out of the oil tank.. so read the manual, and it said put in to level of dipstick, so I put in another 1.5l.. when looking into the oil tank the flow is from left to right.. is this correct?.. after a while, all the oil in the tank disappeared.. so I put more in.. same thing again... the red warning light has come on a couple of times, but I'm putting this down to airlocks in the coolant as the pressure switch is disconnected,, (is there 2?)
The flow in the oil tank seems very good, speeds up when I up the rpm etc..
I'm thinking I have put something back wrong.. maybe the non return valve? is this possible? if this is the issue, how much have I got to remove to change it around?..
I must have put too much oil in because all the gasket are good, no leaks, however then when I put the last 1ltr in I had a small leak from the front clutch housing where the clutch cable linkage is.. so I'm guessing the clutch housing is full of oil...
I'm now draining ALL the oil out and its coming out pretty slow.. when I would of expected it to pour out.. a steady trickle is how I would describe it,, ( the metal sieves were cleaned prior to re assembly)
I'm pulling my hair out.. Please help Guru's
