AceSLive12
If it were me I would pop the bevel box out and see if you have any oil in the swing frame tube? I ma not sure if the breather has any type filter in it to catch debris or oil if it was laid on the shelf full for a while that might have soaked up oil but it does not sound like it since you said you road it for a while. I have seen the seal in the bevel box go and oil travel up into the swing frame tube I also have seen the rear seal on the torsional damper go and get filled with engine oil but that was prior to the rear bearing in it being sealed and filled with grease Pre roadster. I have like I said rotated the gear while filling it and with he oil being thick it coated everything up top and after I got done and closed her up she was over filled which came out the breather I made a note to never rotate the wheel while draining and filling the bevel box and never had the problem again. I usually change mine every oil change or ever other oil change or you'll have a partial liter bottle on the shelf for years![]()
Thanks for all your help - I'll check the levels and refill it once more if needs be, then I'll have a go at opening her up if all else fails
