Updated Rocket 3 be Released?
I believe this is the correct or at least most current custom map on the tuneecu site.
These are them. Notice that for the GT, Penner puts the base map (31249) in his map name. He didn’t put it in the map name for the R. If you open the Penner R map in Tuneecu, you will see that the base map is 31255_01. When you connect to your ECU with Tuneecu, it will tell you the map that’s loaded. If it’s not 31255, you could have a problem with the Penner map.
