HellFire
the GiPro would actully compliment the removal of the secondarys do I understand you correctly. Thank You very much for such a concise answer.
Cheers
Hans:bch:
Yes, pulling them out makes the throttle response much snappier with less delay. Someone once complained that now his was "too" responsive and reacted to every twitch of his wrist, .... I kinda thought that was the point.
Guys who have done this inexpensive mod, including myself, have said that it's the biggest bang for the buck possible on a near stock/stock R3. Having the gear indicator was enough by itself to warrant me buying one, I was always looking for 6th gear at bad times.
The ATRE (Advanced Timing Retard Eliminator) was an interesting feature that put the GiPro top of the list in my choices. Of course after I got it all hooked up and started playing with the settings, the new found performance was wonderful. I got on the website and had to tell everyone about it since I was really excited about how it worked, thats were guys suggested the secondaries should come out too. I wanted to do the triples anyway, so while I put those on I took out the secondaries at the same time. It was like a different bike after that ... scary and fun at the same time. The hardest part about removing the plates was getting the air plenum off the bike, since it was going away as part of the triple K&N mod anyway, the plates are nothing.
I suggest you use the search box and look up "K&N triple filter mod", "removing throttle plates", "GiPro install" etc.... and related threads. some will have very useful pictures and help with the tricky parts.
My only other important suggestion is that you not under any circumstances change the factory Triumph tune to any other software by Triumph
, their tunes are a waste of money & wouldn't work without the throttle plates much anyway. After you do all the stuff you talked about, later on you can think about having a PCIII and DynoJet tune done to tweek that last bit of power out of her with the stock pipes.
Also, while you are putting in the Y-pipe to replace the cat-box, I suggest you use a high temp exhaust connection sealer (tube or putty) on all the slip-on joints to reduce the possibility of deceleration popping (back-fire). The joints don't seal well and suck fresh air while decelerating causing the exhaust gasses to re-ignite in the mufflers. It's mostly just annoying but can cause the packing to come appart over time. If I can help, just ask.
