TuneECU 20352-2Map HELP
wildman
Greenville, SC.
TuneECU 20352-2Map.hex by Life Almberg
Has anyone tried this tune on the stock 2011 R3R with no mods, to open the secondaries 100%.
When I tried to download it to my bike, I get a warning, incorrect values may cause engine damage.
Do all tunes give this warning, or is this tune not really compatible with the 2011 R3R. It is supposedly based on the 20352 Stock Tune.
I believe this is a stock warning. I installed a different TuneEcu map on my bike late last week and received the same pop-up warning right after I clicked on "download". Made a slight change to the map I installed and downloaded it again yesterday...got the same prompt at the same time (just after choosing DOWNLOAD). I then clicked "OK" and downloaded the map just fine and bike runs great. Appears to just be an "..are you sure?" warning prior to changing ECU mapping.
Wildman, be sure to post the result after you have installed the tune and taken the bike for a ride. I am considering doing the same to my stock Roadster.
In short the answer is YES
the warning will come up every time you make a change or down load a tune, it's there to make you THINK before you Jump Without Checking the tune you are loading and to protect the software makers if YOU make a Boo Boo and change things your self or load tune that is not suitable for your bike
RESULTS for Tune 20352-2map.hex
Hey MOTOLINK, I downloaded the tune yesterday to my bike and would highly recommend it. The bike is completely stock, except I did remove the plastic intake snorkel under the seat to make room for my Alarm Parameter Sensor and RF Sensor. This also makes the seat from more comfortable.
The new tune feels like a 15 to 20% increase in power throughout the powerband and full throttle roll on will now raise the front tire a couple of inches briefly. It's still not enough to pull a Weelie, but does increase the thrill factor.
