Tune for jardine and triple k&n
I have triple K&N's and TORs. Dealer hates PC3s and loaded Triumph tune. Seems to run good, but am I losing a lot of power? Wouldn't it be popping if it was way lean?
The stock TORS maps are far from optimized for performance.
Popping on decel tends to indicate lean during decel only, not the rest of the map. You can easily be too lean in some regions, and too rich in others.
There is also a map on the TuneECU site for Roadsters running slip-on silencers like the TORS, D&Ds, StainTunes, etc. Try it, you can always go back to the stock or TORS maps.
I tried the map listed above, but had bad results. It idles at around 2500rpm, and doesn't shut everything off. My GIPRO stayed lit, and the solenoid(?) at the idle stepdown buzzed constantly. Perhaps I did something wrong?
Make sure your Gpro is set to "off" thats the "-" before you download a tune map to the ECU.
I made this mistake and all sorts of things happend.. I set the Gpro off and reloaded the map.. all sweet :)
Write your reply...
