TheMadScientist
That is good to hear. Keep a eye on the clutch free play if it is not right you will not get full gear engaugement. if it starts popping out of second gear it will most likley be in need of the new style gear cluster and a few belllevill washers. With any luck it will not be that. Now matter what oil you use even synthetic which is good stuff if it starts to shift rough that is a sign of it needing a oil change. What brand and weight of oil did you use if I may ask. ALso pleas verify if it is a 06 I beleieve you stated it was. and if so is it a classic or standard? Good to hear she is acting better my friend.
I used Mobil 1 15/50 full synthetic. I don't know if it is a classic or standard. The paint I believe is factory. Pic below.
