warp9.9
Pocałuj mnie w dupę
OK @Loanstar' I have to ask can you point out this weep hole you are referring to? I only know of the three in each spark plug hole which drain out by each throttle body (so the spark plug holes do not fill up with moisture) and the weep hole in the water pump. But I am not aware of one at the rear of the engine except the crank case breather vent if that is what your talking about.I'm about to look at tightening these. I have a very small amount of oil coming from the weep hole at the rear of the engine. I can't open the service manual on my phone. Are these relatively easy bolts to access on the oil-tank side of the engine?
