Do you have a 240/50R16 rear tyre?
iirc, they run 77mph at 3000rpm with no change to speedo connection from stock in the map. At this gearing, 6500rpm would be 268kph.
So,if I got it right, 6500 R3 tacho is 6500, for example Dynotachorpm ? Rear tyre = 240/55 R16
They have a drop down/preset for the 13-16 roadster, though I cant vouch for its accuracy (I'm fairly certain the primary drive ratio is incorrect for a 2005 model). If you know your numbers you can plug-n-play any data and see what's up.
Dyno, but careful don't say that, it'll ruin sunny's day, it's his favourite video, i think he is under the impression that the bike will accelerate like that and hit that speed on the road lol
If he brings his own wheel rollers and wd40...
this is an older model ofcourse and doesn’t compare to the efficiency of the new more superior drivetrain but for amusement, its a 200hp unit so not much i know, Here are 4 rips with 80mph interstate speed in between red line pulls, trying very hard to help alot of that get to ground. New video pull coming soon.
love the "on a need basis" protection!
The new rockets are beast, can do it all, but running 170mph it have to loose alot of weight and get even stronger. I love the new rocket but even these guys run that and look how thin and strong they are, a few examples not to compare against a rocket just showing speed and power weight on all not much. takes a lot to go over 170
