Thank you my friend. By your quite accurate and reliable reading, 3000rpm in 6th will be about 75.2 mph (121kph).
80mph (129kph) would be about 3200rpm in 6th. Speed at 7000rpm in 6th about 176mph (283kph).
The amount of drag increases at least with the square of the velocity, with drag exceeding other factors past about 40 mph.
So a little more power makes available less speed.
Almost all geared vehicles are power limited.
And measurement instruments are almost always most accurate in mid-range, and why a properly matched speedometer will go far higher than the vehicle is designed.
