The Three Sisters, aka The Twisted Sisters
A wet sump system has a pan or cavity that oil drains to by gravity where it is picked up from by the oil pump. A dry sump system uses a second pump to pick up oil from the crankcase and move it to a storage tank where it collects and entrained air bubbles can be eliminated or reduced. So, the R3 is a dry sump system. Engines that run inverted or in any orientation for that matter use multiple pickups and/or flexible pickups that swing based on G force.
As to if captured air in the oil system will show pressure on a gauge; YES! Add to that the response time of the oil pressure sensor and you can have low or no oil pressure intermittently and not know it.
The oil pick up in the tank will, should not, be an open ended tube as the those are prone to cavitation from swirl (like water draining in a bath tub creating a swirl and then air goes done the center of the vortex. It most likely is a tube laying parallel to the tank bottom with multiple holes in the side or bottom next to the floor of the tank. But I have not cut one open so it may differ.
Based on Steel's explanation of what happened, I would hazard a guess that the cam bearings in the head seized from lack of lube. This would lead to the cam chain jumping off, breaking, or shearing of the lower sprocket key. A main or rod bearing failure would likely lock up the motor leaving Steel with a wild ride till stopped. The fact it has no compression means it turns over but without cams rotating, no air in or no compression due to open exhaust valves, and of course those that can't close due to bending from contact with the piston crowns. Likely, all pistons are toast as well as the head. Main and rod bearings may show signs of distress as well.
Carpenter may have a point about wheelies leading to the failure. The passages to the cam bearings are very small/restricted so that they receive no more oil than needed. If they are too large, the excess oil fills the head so that the valve springs and cams run submerged in oil. This leads to excessive oil consumption and high oil temperatures. Additionally, the oil is whipped into a froth that becomes largely air (like whipped cream) which then leads to oil related failures as the engine circulates less oil and more entrained air. On the other hand, lack of lube to the cam bearings will degrade the bearings and they will eventually fail.
What is less obvious is that the Carpenter head has much greater valve spring pressures which puts greater stress on the cam bearings. They may or may not have changed the oil passage size to increase oil flow to help compensate, or may have found that doing so is not needed on the R3. ???
If I were to wheelie my R3, filling the oil tank to the point just short of blowing the cap off would be first on my agenda. (Or perhaps change the cap to a locking one that can't blow off and fill until it does puke oil when hot, after which you would know how much oil to put in.) Much better to puke a little oil out the breather than have a catastrophic failure.
Reminder here: this is an opinion based on my knowledge and experience: I have not examined Steel's motor. And I do not imply that Carpenter is at fault in any way.
I new someone smarter then me would come along :) personally I do not do wheelies. Mostly because I don't want to be embarrassed when I ask somebody to help me pick up my bike:D
I will make it a point to cut open a tank when I get home in November. Now that you explained things better I am wondering if there is multiple holes along the bottom of the pipe what if some of the front ones suck air while in a wheelie or maybe they all stay submereged. And another thought just popped up in my mind which is. Since the pressure and scavenging pump work directly off engine rpm and the extra oil bleeds off into the trans area this must be worse say at 8000 rpms can the scaveger pump return the oil fast enough so the tank stays relatively full so the supply line does not suck air. And does the baffle the returning oil runs across to help iliminate air bubbles get a chance to do it while at a steep angle like in a wheelie. My guess would be things are not as efficient at that point or even at longer high rpm runs. Just thinking out loud. I better get back to work Mathew is coming!!!!!!!!
All good questions. Most likely the holes are close to the center of the tank and between vertical baffles as any G-forces would move oil away from the ends. Most dry sump tanks are small in diameter and tall to better constrain oil movement during acceleration. (Acceleration happens in all directions; think of cornering, hard braking, fast take off, or wheelies.)
The scavenge pump's (or multiple small pumps, some even with separate pick-ups) capacity is generally at least 3x greater than the pressure pump to insure that oil and air are returned to the tank. The tank removes air using baffles, flow tangential to the tank walls where oil spreads in a sheet allowing bubbles close access to the liquid surface, and sometimes by lowering the tank pressure below atmospheric.
Oil tank capacity, or oil pan capacity as well, has to be big enough that under high rpm the oil pump doesn't run out of oil. The R3 crankshaft and rod rotating assembly at 8,000 rpm probably holds 1 quart or more of oil suspended that doesn't drain down until the rpm drops. Add to this more oil is in the top of the head awaiting to drain back down because the oil pressure is at its highest and the oil that is there is being slung around by the cams and held captive by valve springs opening and closing at a rate of 4,000 times a minute. So the tank that has oil to the dipstick mark when not running is likely 2 quarts or more lower than that at sustained high rpm. Now add in extra air into the oil so that it becomes an emulsion because the oil has spent less time in the tank de-aerating and you have a recipe for failure if even more air gets in from wheelies at high rpm.
Thanks that helps. I do not remeber seeing any vertical baffles just tbe one running lengthwise across the top that the scavenger return line dumps onto. Thhe line comes up from the bottom and has a bend so the oil pumps out across the baffle. When I cut one open it might be a little clearer.
What's it lookin like guys?????
@breeze
@WyldCFH
although theres nothing more than I would like to do is ride the country with you clowns,work,timing,money,its looking highly unlikely for me to show up,although bull is still planning? on dropping truck/trailer off here at my place until hes done,got plenty of room so he can leave it long as he needs
This is waht you will wake up to every morning, 50 feet from your cabin and for your viewing pleasure
