SebringChuck
For the past week or so I've been having problems with the high beam indicator light. Whenever I would switch from low beam to high beam everything seemed normal but switching back to low beams was when the high beam indicator light would remain on even though I could see the headlamps did go to low beams. It would remain on no matter how many times I flip-flopped the beams. It would finally go out whenever I turned the ignition off and it reset the next time it was turned on. But with the same result the first time I tried the high beams, the indicator light would stay on. I finally got off the bike at a gas station and looked at the headlamps and noticed that one of the headlamps was a lot dimmer than the other one. Next day I replaced the lamp and the problem with the high beam indicator miraculously cured itself!
So if you find a problem with the beam indicator one day, check your lamps.
