The O2 sensor reading -26%
primary tps book says .06 plus or minus .02 volts so final setting would between .58 volts and .62 volts
at closed throttle (with stepper motor retracted.)
i suppose the final reading would depend where u have the stepper motor set at.
i have heard that u can fudge a little on the stepper motor to get a little better idle.
Correct, the closed (.6 volt) tolerance is .02 volts, Open (.75 volt) is .05 volts.
If you're doing this with TuneECU and don't have the TPS adjustment guide, PM me and I will send it to you.
if u can get .75 volts i would think that would be great i am not going to argue over one hundred of a volt.:roll::roll::thumbsup:
Write your reply...
