Recently figured out front fork tubes were not even with upper surface of the top yoke. Came from the factory like that. So we fixed that problem and adjusted the steering bearings for the second time. No we did not loosen the bottom yoke there is no need for that when adjusting the tension on the bearings due to design. Wobble disappeared. Still had a slight wobble over 120 mph. Replaced Avon Cobra with a Dunlop Three Elite and high speed wobble is gone. Run a Bridgestone car tire on the rear and the Dunlop works well with it. Not to crazy about the Avons. Did notice that when installing the front tire the alignment on the left rotor was not centered. Gentle tighten the pinch bolts and pushed in the right fork until rotor on left was centered with the brake caliper. Tighten pinch bolts and everything stayed centered. I can understand how the engine mounts could affect handling but believe a lot of wobble problems stem from improper adjustment of stem bearings and installing the front tire incorrectly. Really like how the Elite Three Dunlop handles.
