Supercharger, or turbo installation information please
Here are some shots of my turbo setup for you. No intercooler. Turbo is below the bike and is not really visible without pointing it out to people. It's extremely noticeable when twisting the throttle though!
Hi thanks for this, again just what I was after. What did you do for mapping on yours? Worried about leaning out. (I remember speaking with you some time back after i commented on your YouTube vid then lost your details somehow). So far have MAP sensor and PCV with AT. So have wide band O2 sensor. Appears I can do pressure based mapping with above. Also have a live Fuel air ratio meter arriving to piggyback onto the O2 sensor to keep an eye on leaning out. What did you dove this?
Sleeves, our setups sound similar. I have a PCV with MAP sensor to do pressure based mapping. I also added the Dynojet ignition module that pulls timing out based on boost pressure as well. It is linked to the PCV over the CAN connection. In addition I've added an AFR gauge to monitor while riding. It's a failsafe gauge with a contact that I use to automatically switch maps with on the PCV if it leans out too much. The second map pulls more timing and ads more fuel.
Haven't quite started ye
Haven't quite started yet got most parts together and just making sure have everything lined up.
The FA gauge just seemed a good idea. Your bike evolved since your YouTube vid by the looks. Smart instrument setup
For oil return where did you put it?
Write your reply...
