Styling opinions please?
Why? They both have springs don't they? ;):p:D........:whitstling::whitstling:
I have a set of Rebands with a CES rear muffler in the shed. I got them from @Mittzy but with a couple of other poor :confused::confused:owners between us. And I have actually owned them twice now, but only once in possession :D
Been researching and Mittzy not only welded them together - " Look no springs Ma! " ;):D
He also plugged and re did the heat shield bosses as the heat shield bolts used to go straight through the pipe wall on early versions. He put the thicker flange plates on as well as matching up to the contrasting CES sourced rear can.
I am not sure if it has a CES collector now too?
Link Removed
If you get them welded together read this excellent advice from our resident exhaust Engineering, Artistry and Craftsmanship guru @Paul Bryant .
Older Reband Exhaust
Link Removed
Yes CES hand made the collector, and no springs on Reband all I did was plug the bolt holes for the heat shield and replace the flanges for thicker ones
