Barbagris, I don't think the battery discharges because once it starts everything is fine, I can shut down and start again without problem. Battery always has 13.75 volts charge or more when I check it and I have a Shorai 540 cc amp battery. Its seems that cold whether does something to interfer with charge getting to starter. I am going to try your suggestion of insulation. If I continue having problem I will try removing cables and reinstalling at end of shift. Will I need to remove both positive and negative or will one suffice?
One will do. Earth is generally EASIER and SAFER.
This is difficult to diagnose remotely. I'd missed your using a Lithium. changes the rules of engagement a bit.
There is evidence that suggests a LiFePO4 battery needs to have some resistance load put across it before it will DUMP discharge when cold. I've not seen it personally - but I understand the chemistry theory.
But it's important to note that an LiFePO4 battery will show high voltage until it's almost drained - whereas a lead acid will drop voltage gradually as it drains. Also HIGHER voltage than a lead acid. It's the nature of the technology and chemistry involved.
How far is the ride to work?- are we sure the alternator is replacing charge used for a prior start correctly?
There are two relays involved. A small one that is activated by the starter button and this in turn passes LOW current to the starter solenoid. If the starter goes CLACK and spins it's NOT the small one. If it chatters - then it can be as the system voltage has dropped enough for the small relay not to function.
It could be burnt points inside the STARTER SOLENOID. ime generally speaking - RARE. Worn Brushes on the starter itself - more common.
Once it starts - the alternator maintains enough power to run - but will only use residual wattage to recharge the battery. However it will put a surface charge on the battery. This will certainly last 10-15minutes. But it's not a deep charge.
It's perfectly easy to load the electrics so that the alternator only has milliwatts of energy available to recharge the battery - but as it's actually charging (albeit marginally) the charging system will flag things as OK. If you have lights, aux lights, heated grips - some other gubbins on - then it's possible this is a factor.
Also there comes a point where as engine rpms rise the total demand engine+
other exceeds what is needed to charge.
I've seen this on the R3 with a full load - and as rpms went up past 3500 the voltage warning indicator I have fitted went into "OK but not charging" mode. The more rpms - the higher the demand - but once you've hit 2000rpms-ish the alternator is already at full supply. Note that OK but not charging is not seen as discharging - so the charging system sees everything as OK.
I fixed this by reducing the "other load" - fitted LED lighting.
Bear in mind it could well be a mix of several small things. But to really see, what you are need tools - VOLTMETER and AMMETER wired and visible whilst riding.
