Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
I just tore my starter off, figured it's quick, might as well clean the contacts internally as preventative. Wiped clean, sanded until polished smooth with 2000grit. You can definitely get to the contacts without removing the starter, but it sure is a whole lot easier to clean inside there with it OFF the bike.
Also, remember step 1: Unbolt battery positive lead
12mm for bolts to engine. 13mm for cable nuts, 7mm for solenoid back cover, you don't need to remove the two over-tightened #1 Phillips screws.
