R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,381
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
Thanks for confirming Paul.
The plan moving forward I think is to buy a new shift drum, input and output shafts, bearings, whichever gear I sheared, and have most of it cryo treated.
While that’s in the mail, Add an MTC billet basket, refresh the exhaust coating (warranty work), and rework the harness by soldering everything. Relocate all the electrics, PC-V, PDM-60, keyless etc to the stock battery location. Send my oil sample off for analysis.
Add the upgraded starter, pull the stock airbox replace with a custom battery tray for a stronger battery. Add a master kill switch so I can disconnect the battery easily and stop any/all parasitic drains.
Remove all the bullcrap extra stuff on the frame that I don’t need (like the rear fender supports being MASSIVE). Pull the wheels, whee bearings, and send out for powder coating along with some little bits here and there I want redone.
Budget allowing: Get the Carbon Dry tank cover and send all the carbon off for candy paint.
I don’t think there’s any chance I’ll be riding in time for RAA West, but I’m **** sure going to try!! If I don’t make it, it’ll be me waiting on a shop or parts from Triumph!
Will post pics as I go, might as well bring everyone along for the ride![]()
While you're doing all this, you could send me your '14 factory fitted ECU and I'll see if the Triumph software will unlock it to take earlier Roadster maps (e.g. the 9000rpm one) like my '17 one does
