I’m going to adjust the way I ride the rocket and get my Daytona servicing done so a I can ride that as an alternative.
Transmission plans:
Replace the broken gear (or gears) and have them back cut at Robinson prior to getting WPC coated.
Upgrade Circlips - larger ones with bigger grooves. Spoke with Robinson this morning, he quoted under $100 and 2-3 week lead time.
WPC Treatment on the following - Shift drum, all forks, shift rod, detent wheel, clutch actuation rod, Tapered Lifter, 1-5 input, 1-5 Output, input shaft, output shaft, gear position rod, shift arm and actuator, oil pressure pump gear, chain, and driven cog.
I have been looking into getting custom primaries cut, so far, no takers, they don’t even want the work for the shops I’ve tried.
