Run premium fuel?
I think back now I think the Old timer was saying mix Shell and Mobil I think it was the high octane, but I think I'm going to try the 87 octane the 08 r3t manual recommends and mix them both, the I'll take my plugs out in a year and repost them here!!! I remember I used to do it in my 70 mustang and it ran pretty good, never had trouble with the motor, I didn't do it all the time, that would be a pain in the arse though, I don't know where I got Amoco from they do transmission's don't they, but I think at some time they had a brand of gas??? I just researched it they merged with BP.
I just have to find a Shell station on my route, there's Exxon's all over the place
When you buy 89 octane the pumps automatically mix 87 and 91. The gas station underground tanks only hold two types of gas. (If you go to a Chevron in BC, they have 94 and 87, which get mixed to 89 and 91)
I am going to expand on a few things in this thread. There is a good explanation already but a picture might help more. Not captured in the below picture is MON uses variable ignition timing to further stress the knock resistance of fuel.
95 RON is the same as (RON+MON)/2 87.
The old timer that talked about mixing fuel is talking about leaded gasoline. Way back in the day when you mixed low octane with high octane it would result in a number almost as high as the high octane version. It had to do with the chemistry of the fuel. That doesn't work any more and now you will just get the average.
Reading the plugs on a modern vehicle is not going to give you the information near like it did versus a vehicle which has a carb. The new vehicles have an O2 sensor (or several) which gives continuous feedback and adjustment of the fuel mixture. The old carbs are not self correcting like the fuel systems of today are.
Putting in 87 octane is not going to hurt your engine. If you do hear knocking or pinging then you need to step up an octane rating or find a different fuel. No knocking or pinging, your engine is going to run fine and cause no damage. If you find yourself someplace you can only put in 85 you can still make do with that fuel. Just don't lug or hot rod the bike, keep out of full throttle and drive it calmly and you will be fine until you can get to a place with the correct octane.
I do want to talk about the old timers giving advice. While they might have really known their stuff and maybe still do, the experience they have, which they are basing their knowledge on, might not have changed, while the vehicle technology did. The things my dad told me while he was driving his 1969 Roadrunner might be out of date when talking about my 2021 Lexus. Some things will hold true still and some won't be helpful and could even be detrimental. When the old person is giving you advice, just keep in the back of your mind how the changes in technology might have made the advice not as relevant today.
I will give a personal example. Long time ago if you had talked to me I would have told anyone wanting to put a turbo on a car that it is a bad idea. Performance, the lag, the headaches associated with them were not worth it (blow through carbs). I would have told you that they are for tractors and semi trucks, motors that run at a constant speed for long periods of time, and diesel was the best fuel to use with them. Fast forward to today and I would tell you turbos are great, the technology with the fuel injection has made them a very viable performance option. I had to change my thoughts because of the evolution of the industry. That is just one area, there are a ton of things I would have told you years ago that I wouldn't tell you today. Just like how you use computers through the years and the advice you would have given on the windows 3.1 system wouldn't apply to windows 10, same thing with vehicles.
Just to clarify, at the top you said 95 ron is = to 87 octane? Is this correct?
One old timer's view of timming.
First of all u could by gas that was 103 octane and u could loosen a bolt and put in as much timming as u wanted then tighten the bolt. lol
U could could also use a vacuum advance above the throttle plate or below the throttle depending on what u wanted aslo adjustable vacuum advances. Not to mension the mechanical weights and springs that were available in different weights/shapes and and different
spring pulls. Basicly u could set it any way u wanted and the young electric guy came along and said we can fix that for u. Lol
We can half ass it so it will work fair and wont ping but it is never going to b right and if u want it right u r going to have to pay through the nose to and let some young buck work with maps and tables to where he thinks it is best.
We all know this is best for everyone.
Think I will try the vaccum advance above the throttle plate method. Thanks!!
