They are bog standard H3 bulbs - BUT the power wire (white) has had the spade connector removed and is soldered into the longer wires that run back under the tank. It makes what should be a 5minute job into a 30 minute one - or a nightmare if you don't have the tools.
Outstanding.....I figured you'd have the answer. I am thinking of pulling the bulbs and upgrading them.....if I can find a replacement. I upgraded my headlamps and now the fog lamps look pathetic.
Once again thanks for the response barbagris.
With access to decent machine tools and a bit of ingenuity - Conversion to LED is do-able. Mine are. To get the best benefit you do need to machine the insides though. A rough and ready conversion takes less time and is reversible - but the gains are less visible.
I really like the fog lams for the Rocket but the brakets cannot handle high speeds. They suffer from stress fractures ofter a short while. At regular road speeds they hold up well and give great visability.
