IT WORKED!
On the advice of suggestions from this forums and other on the Web, I did the following with success:
1 - Easy Off Fume Free Oven Cleaner (Blue Top), spray and let set for 2 hours
2 - Warmed the pipes up for about 10 minutes
3 - Super fine (#0000) steel wool
4 - Add a little elbow grease (just a little)
5 - Cleanup with wet cloth and a dry towel
Good as new (or at least before it was caked in melted plastic bag)!
Thanks all for your input.
If you really care about the chrome
gleaming....
PLEASE... DO NOT USE STEEL WOOL ..even 0000. It will leave swirls in the chrome that you may not see unless in bright light or sunlight.
Been there...
BELIEVE ME!
I have had a few of these polyester meltings and have tried acetone, brake cleaner, carb cleaner, blue job, paint thinner, paint remover, Goof Off, gasoline and every kind of pad imaginable.
I have found that the EZ Off oven cleaner
DOES work but
not in 2 hours...at least in my experience..
First remove as much caked on stuff as possible using wooden or plastic scrapers or fingernails. Do not heat up the pipes!
DO THIS ON COLD PIPES!! Then put a heavy coat of EZ Off (Blue top) cold oven cleaner on (being sure to protect any paint or aluminum).
Then comes the big trick...WAIT 24 HOURS at LEAST!! Keep your impatient hands off!!
The plastic will be softened and easy to wipe off with a paper towel. You may have a bit left so re-apply...
wait 24 hours again an all will be gone.
I used 0000 steel wool on my pipes once before and all seemed good until I saw them in the sunlight or even a high intensity flashlight. It destroys the luster and you have dulled chrome. It depends upon how compulsive you are about your chrome. Few will notice the dulling when you have used 0000 steel wool but
YOU will!
I speak from hard won experience having screwed up a feces load of chrome over my many years of riding.
I think it has finally sunk into me that
ANY kind of abrasive will adversely affect the original finish of chrome. All of these so called non-abrasive chrome polishes like Simichrome, Blue Magic, etc..scratch the chrome! The only two products I will consider are Windex and Blue Job for maintenance and EZ Off for melted on feces.
50 years of biking and still learning!
I have to say, I have not tried
"Bronze Wool" as one guy on line suggested was the best but have just ordered some from Amazon.
We'll see...still learning!
