barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
OK - IF you have access to a Dyno-Guy who really knows what they are doing with TuneECU - Then DYNO IS BEST.So you'd suggest either PCV / AT install or hit the dyno with a direct ECU update NOW, anything to remap properly? Then update as I go with the mods...If I went the PCV route, does this mean I can map myself (using AT) or would it still be best getting dyno runs in? Just trying to understand where the costs might be...
But comments from forums and from my experience here is that they are few and far between. I'm sure Rob (@Claviger ) has a Q&A test to weed out all but the very best. All that Alpha-N, transition ritchening jargon that will generate FUD in all but those who understand. And from what I have gleaned with some 8 years of following R3 tuning advice from some of the guys than KNOW - the R3 is a wee bit awkward in some areas - VERY FEW Dyno Gods get a full positive reference on here - there is (I suspect) a good reason.
Most seem ONLY to tune for WOT (power baby). So they ignore the L tables. This is (imo) ignoring a valuable part of the ECU possibilities that Triumph put there for a reason.
The PCV with A/T does however offer tuning functions beyond that. AND significantly you can see the results and ANALYSE them. If you add the POD300 then you can also LOG a mass of data. The PCV will allow you to do a different map per gear without breaking a sweat. The PCV will allow you to re-map using Manifold pressure.
If you have the TIME and an analytical mindset then the PCV-A/T-POD route is imo a very good one (but as I chose this - I would say this).
If you decide to go the self help route - you NEED data. Lots and LOTS of data. Also bear in mind that apparently insignificant things make a difference. So logging matters.
I live at 700plus metres altitude - often ride at 1000m and maybe down to 650m - A non adapting map generated at sea level will have me running WRONG.
Also temperature. I noted early on a distinct change in how the stock ECU reacts as it crosses specific temperature thresholds. iirc around the 25-26°C barrier. If (like me) you can have sub 25° mornings and over 35° afternoons it makes it all a chore. This, in the UK, is maybe less of an issue
I started using the Torque App and a cheepo bluetooth box on the OBD connector. Gave me TPS, RPM and KMH - This was enough to start and via TPS tuning I'd say I got about as close as I could. The PCV-A/T made it a lot easier and for me importantly allowed me to do a map per gear - because I do not ride the same in 5th as in 3rd. Most of us do not at a guess. But yeah lets tune the same for all gears
I am in the throes of changing to manifold based tuning and have to say that SO FAR this way outclasses TPS based tuning for general road riding. It is simply smoother. Rob was marvellous this weekend in helping me diagnose a sensor calibration issue and also making some AFR modification suggestions. With a bit of luck those will get a decent run tomorrow. Thursday is my play day.
THE DIFFERENCE is that the PVC-A/T will automatically start to readapt straight away when you make changes - like the RAMAIR or a new header. There are things you will still need to tweak with Tune ECU - but more as setting an environment to which the PCV will then modify fuelling accordingly. We never stop learning.
