Pcv/auto tune decel popping
I thought the PCV with auto tune is supposed to take care of all of that??
Mine has gotten much better then it was, Auto tune is making a difference in the decel popping now a nice deep rumble more then gun fire....
But the seat of the pants meter feels a loss of power in low end. So I want to get a dyno tune done so I know what I have.
I would have to look again to be certain, but I believe that at the zero percent throttle all the values are zero and PCV/Autotune won't adjust that area. That is where the map installed to the ECU comes into play. I could be wrong though.
Hanso is pretty up to speed on the PCV/Autotune setup. PM him, or hope he sees this thread and posts.
I haven't had any troubles with my bikes setup with the PCV/Autotune combo. 08 touring w/ trips and TORS. Whatever the stock ECU map is for TORS and a PCV map from Hanso. I get a backfire occasionally but can't ever recreate it on demand so I don't think its a problem.
Best of luck!
Best of luck!
I have sent Jay a copy of the map he was using but with the L tables modified so I am hoping to hear from him saying all is fine and yes the PCV doesn't affect the zero throttle area the auto tune does not start working till 2% throttle. I have to make some time somewhere and hook up the speed and gear sensor wires so I can really explore the full extent of the PCV usability, have been thinking about buying the LCD module that lets you make changes a switch between map, has anyone out got one?
