Ramair filter arrived...
The first filter design I had made by ITG had a power capacity of 300bhp according to their estimation. It also allowed retention of the stock coolant header tank but not a stock bearclaw (below). I'm sure ITG would make more if asked.
I now have it back in the UK and will be trying it at the first opportunity to see if it runs any quieter than the Ramiar - I think unlikely that it will but you don't know until you try.
Art, if you wanted to try it out it could be sent over to you but I would want it back.
You'd need to be fair and run it against an un-claw'd RAMAIR - A fair bet it will make WHOP WHOP sounds. Maybe the Halibut slap. Doubt it'll chirp. Technical chat this eh?!
That looks like a Pipercross filter, and it's rated at 300 hp also.
ITG, PIPERCROSS and RAMAIR all use pretty much the same filtration technology. If I was forced to choose - I'd give preference to ITG's foam. I've used filters now from all three - NOT all on an R3. RAMAIR offers a serious price advantage - and so far has not let me down - I use their filter medium in my Land Rover as well.
Ideally I'd run a pre-filter screen of Stainless in dusty environments - hard to do on a bike where space is at a premium. i.e http://www.ebay.co.uk/itm/STAINLESS...arts_Vehicles_CarParts_SM&hash=item460c3ba4b5
I say again - PRE-FILTER - I have something similar from a different mfr. Keeps larger lumps off crud away from the real filter.
I think they do.
Well done that man - Close up and model details required, please! - Looks like one side of a Porsche 911 kit. Air Temp sensor inside? - You're not getting away with just a long range shot - no sir, you're not!.
I'd have thought that with the filter correctly oiled it'd make a mess of your knee though - I'd wear the foam fast too - as I grip the tank with my knees in the twisties.
I was wrong. After looking again, it's a 290hp filter, part number C504D. It does need a backing plate made for it. I used the stock velocity stacks from the air box.
I didn't mount the air temp sensor inside, but Warp 9.9 drilled a hole and mounted his sensor inside.
I didn't like my knee being against the filter either, plus I didn't like the look without the bearclaw. So I moved the water bottle, shifted the filter forward, and trimmed the claw to fit.
I originally looked at the C504D and spoke to Warp about it, he mentioned about the knee problem and that was when I decided to get a special from ITG. Its shorter and narrower than the Pipercross and would allow keeping the tank and fitting a bearclaw modified like you have done.
Mind you the Pipercross is a cheaper than the ITG, but that is to be expected as its not a special.
Write your reply...
