Radiator Cap Alternative
Some good reading:
Beating the Heat: Advantage of a High Pressure Radiator Cap
The most critical bit from the dissertation:
In particularly hot areas with engines that are running high compression or boost, a 1.3 bar radiator cap, water wetter and a reasonable coolant ratio or distilled water setup would be a good "stock upgrade" to help prevent detonation.
The KTM 59035009000 is also 1.4 bar!. KTM 58035016000 / 59035009000 - RADIATOR CAP SMALL 20,3 PSI | CJ Designs LLC
KTM 59035009000 en venta | eBay
Nope! The locking screw is over engineering and finding a fix needing a problem at its finest imho.
Actually I think it is part of the problem. In the past folk have removed the lock screw and achieved a better seal.
Rob. At what temp are you switching the fans on? I had them set to come on early but I have a feeling I put the setting back to stock. I am going to take a look at mine today - amongst other things.
DEI radiator relief if you decide to use a water wetter!. I do on Wayne Tripp's advice.
97c is activation temp.
My problem started on an 88f day that was humid and I was riding the balls off the bike, holding 4500+ rpm through a 4 mile set of twisties up and down 2nd and 3rd gear, which we’d run, u turn, run, u turn, run, u turn, run and stop for a break. Essentially a 6 session trackday type day. There were a calamity of things that led me to suspect head gasket but I’m trying this first since there are zero other head gasket symptoms that present.
So the 1.4 I’m going to use and give the cooling system every opportunity to do its best before I rip the head off.
I hit the problem in Traffic - Something I do not normally suffer from.
But was a PITA in the UK and yesterday had to sit whilst the police/ambulance picked up assorted bits.
I was told that the water pump starts to cavitate at 4000. Food for thought.
I have been thinking pump, it’s super suspect. Looking into this as a retro fit replacement in the stock location. I have the extra electrical capacity, full led conversion and zero accessories that draw any load:
EWP115 Alloy & LCD Controller Combo (12V) - Part No: 8850
Or the 80 version which comes with in/out provisions similar to rocket stock and is a bit smaller.
